简介
This guide will intructs you how to remove the front wheels from Protocol TerraCopter Evo. Removing the front wheels will require you to remove the propellers first then you will need to disconnect the front wheels from the drone's lower board.
你所需要的
Using a Phillips #0 screwdriver, remove the four screws connecting the propellers to the device.
Use a plastic opening tool or a spudger to separate the drone's cover from the body of the drone.
Remove the connector of the drone body and the back wheels using a plastic opening tool.
即将完成!
结论
