跳转到主内容
Protocol Slipstream WiFi Camera Replacement
你所需要的
  1. Protocol Slipstream WiFi Camera Replacement, Camera: 步骤 1 中的图像 1,2 Protocol Slipstream WiFi Camera Replacement, Camera: 步骤 1 中的图像 2,2
    • Remove the four 5.5 mm Phillips #00 screws that hold the lower canopy to the upper canopy.
    • Gently pull the lower canopy up and towards the back of the drone. The lower canopy will still be attached to the upper canopy by 3 wires. Just set the lower canopy aside and continue with the repair.
    • Be very careful when pulling the lower canopy apart from the upper canopy. There are 3 wires that will still be attached between the lower and upper canopies.
  2. Protocol Slipstream WiFi Camera Replacement: 步骤 2 中的图像 1,2 Protocol Slipstream WiFi Camera Replacement: 步骤 2 中的图像 2,2
    • Remove the four 5.5 mm Phillips #00 screws that holds the battery tray to the lower canopy.
    • Once the four 5.5 mm Philips #00 screws are removed gently pull on the battery tray to separate it from the lower canopy.
  3. Protocol Slipstream WiFi Camera Replacement: 步骤 3 中的图像 1,1
    • Use a spudger to gently pry around the outside edge of the camera to remove the camera from its mounting hole.
    • Be careful when removing the camera from its mounting hole as there is a small ribbon wire that connects it to the computer.
    • The camera and computer assembly will now be free to move. Move the lower canopy out of the way for now.
  4. Protocol Slipstream WiFi Camera Replacement: 步骤 4 中的图像 1,3 Protocol Slipstream WiFi Camera Replacement: 步骤 4 中的图像 2,3 Protocol Slipstream WiFi Camera Replacement: 步骤 4 中的图像 3,3
    • Use the flat side of the spudger and push the 2 tabs on either side of the camera connection on the computer and push the tabs towards the front of the drone (away from the computer).
    • Make sure both tabs are all the way out otherwise the ribbon wire for the camera will not be free and you can damage the wire by pulling on it.
    • Now remove the camera ribbon wire from the camera connection on the computer.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 306
