跳转到主内容
Protocol Slipstream EVO Propeller blades Replacement
你所需要的
  1. Protocol Slipstream EVO Propeller blades Replacement, Propeller blades: 步骤 1 中的图像 1,1
    • With the drone flat on the ground identify which propeller you will be replacing.
  2. Protocol Slipstream EVO Propeller blades Replacement: 步骤 2 中的图像 1,2 Protocol Slipstream EVO Propeller blades Replacement: 步骤 2 中的图像 2,2
    • Using two fingers, place them on each side of the propellor near the middle.
    • Pull straight up with force. The propellor will feel as if it will not come off but do not be scared to use some muscle.
    • Warning: Pulling at an angle will result in bending the motor's needle.
  3. Protocol Slipstream EVO Propeller blades Replacement: 步骤 3 中的图像 1,3 Protocol Slipstream EVO Propeller blades Replacement: 步骤 3 中的图像 2,3 Protocol Slipstream EVO Propeller blades Replacement: 步骤 3 中的图像 3,3
    • Checking the underside of the propeller there will be a letter which will correspond with each side of the drone
    • On the corner of the drone where the blade mounts onto the motor you will see which blade you should be using.
    • Warning: Failure to match the propeller blade to the right motor may result in the drone not flying.
    • Lining up the propeller blade with the needle, push down until the propeller is flushed.
结论
Michael Dang
于04/10/17注册
301 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 的会员
UWT-LINER-S17S3G3
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 604
