跳转到主内容
Protocol Slipstream EVO Propeller Guards Replacement
你所需要的
  1. Protocol Slipstream EVO Propeller Guards Replacement, Propeller Guards: 步骤 1 中的图像 1,1
    • With the drone flat on the ground, identify which propeller guard you will be replacing.
    • The front of the drone is where there are no wires exposed.
  2. Protocol Slipstream EVO Propeller Guards Replacement: 步骤 2 中的图像 1,2 Protocol Slipstream EVO Propeller Guards Replacement: 步骤 2 中的图像 2,2
    • With the plastic opening tool, pry the side of the guard closest to the front or the back of the drone depending on where you decided to start from.
    • After prying off one side of the guard, pushing down on the same side will release the other side of the clip.
    • Repeat this step for the following side as needed.
  3. Protocol Slipstream EVO Propeller Guards Replacement: 步骤 3 中的图像 1,2 Protocol Slipstream EVO Propeller Guards Replacement: 步骤 3 中的图像 2,2
    • With the replacement guard line up the clips and push the clips into place.
    • After the guard has been attached to the drone, pinch the clips as you push the guards to ensure they are secured.
结论
Michael Dang
于04/10/17注册
301 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 的会员
UWT-LINER-S17S3G3
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 236
