跳转到主内容
Protocol Slipstream EVO Battery Replacement
你所需要的
  1. Protocol Slipstream EVO Battery Replacement, Battery: 步骤 1 中的图像 1,2 Protocol Slipstream EVO Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • On the bottom of the drone unscrew the screws next to the battery, using the screwdriver provided.
    • The picture shows one of the screws you will be removing, the other screw is directly across from the one being presented.
    • Tip: Removing the screws will loosen the frame of the drone allowing the battery to be removed easier. If you do not want to remove the screws skip to step 2.
  2. Protocol Slipstream EVO Battery Replacement: 步骤 2 中的图像 1,3 Protocol Slipstream EVO Battery Replacement: 步骤 2 中的图像 2,3 Protocol Slipstream EVO Battery Replacement: 步骤 2 中的图像 3,3
    • Pinch the side of the battery that is already exposed and pull until the battery is fully removed from the drone.
  3. Protocol Slipstream EVO Battery Replacement: 步骤 3 中的图像 1,3 Protocol Slipstream EVO Battery Replacement: 步骤 3 中的图像 2,3 Protocol Slipstream EVO Battery Replacement: 步骤 3 中的图像 3,3
    • With the replacement battery, insert it where you removed the faulty battery until it fully secured within the drone.
    • Replace screws that were removed earlier if you did not skip step 1.
结论
Michael Dang
于04/10/17注册
301 声望
创作了3篇指南
团队
UW Tacoma, Team S3-G3, Liner Spring 2017 UW Tacoma, Team S3-G3, Liner Spring 2017 的会员
UWT-LINER-S17S3G3
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 501
