跳转到主内容
Protocol Galileo Stealth Motor Replacement
你所需要的
  1. Protocol Galileo Stealth Motor Replacement, Propeller: 步骤 1 中的图像 1,1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Motor Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Motor Replacement: 步骤 3 中的图像 1,1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Motor Replacement, Housing: 步骤 5 中的图像 1,2 Protocol Galileo Stealth Motor Replacement, Housing: 步骤 5 中的图像 2,2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Motor Replacement: 步骤 6 中的图像 1,1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  7. Protocol Galileo Stealth Motor Replacement, Motor: 步骤 7 中的图像 1,2 Protocol Galileo Stealth Motor Replacement, Motor: 步骤 7 中的图像 2,2
    • Remove the 3 outer 8mm long Phillips #0 screws from the lower drone housing.
    • Remove the 2 inner 3 mm long Phillips #0 screws from the drone motor.
    • Place screws in a safe place to prevent misplacing them.
  8. Protocol Galileo Stealth Motor Replacement: 步骤 8 中的图像 1,1
    • Remove the two 6mm long Phillips #0 screws from the lower motor cover located on the underside of the drone.
    • Place the screws in a safe place to prevent misplacing them.
  9. Protocol Galileo Stealth Motor Replacement: 步骤 9 中的图像 1,1
    • Remove the motor cover by lightly pulling it away from the drone.
  10. Protocol Galileo Stealth Motor Replacement: 步骤 10 中的图像 1,2 Protocol Galileo Stealth Motor Replacement: 步骤 10 中的图像 2,2
    • Unclip the wire plug by applying light pressure to the wire plug with the plastic opening tool, and remove the motor.
    • This plug can be a bit difficult to remove, but it does not require much force to remove.
    • Avoid damaging the plug and wires when unclipping wire plug.
结论
另外一个人完成了本指南。
Matthew Selting
于02/15/18注册
432 声望
创作了4篇指南
团队
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,094
