跳转到主内容
Protocol Galileo Stealth Light Emitting Diode (LED) Replacement
你所需要的
  1. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: 步骤 1 中的图像 1,2 Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Housing: 步骤 1 中的图像 2,2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  2. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 步骤 2 中的图像 1,1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
  3. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement, Light Emitting Diode (LED): 步骤 3 中的图像 1,1
    • Remove 6mm Phillips #0 screw from the LED strip.
  4. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 步骤 4 中的图像 1,1
    • Remove the LED strip from the housing by applying light pressure away from the lower housing with the plastic opening tool.
    • Take care not to damage the LED strip when removing it from the lower housing.
  5. Protocol Galileo Stealth Light Emitting Diode (LED) Replacement: 步骤 5 中的图像 1,1
    • Unclip the wire plug from the motherboard by applying light pressure away from the motherboard with the plastic spudger.
    • Avoid damaging the wire plug, wires, and motherboard when removing the wire plug.
结论
Matthew Selting
于02/15/18注册
453 声望
创作了4篇指南
团队
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G4
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 253
