跳转到主内容
Protocol Galileo Stealth Housing Replacement
你所需要的
  1. Protocol Galileo Stealth Housing Replacement, Propeller: 步骤 1 中的图像 1,1
    • Remove the chrome shaft cover by lightly pulling it away from the drone.
  2. Protocol Galileo Stealth Housing Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the 7mm screw from the propeller stop.
    • Be sure to apply adequate pressure when removing the screw to prevent stripping it out.
  3. Protocol Galileo Stealth Housing Replacement: 步骤 3 中的图像 1,1
    • Remove the propeller stop from shaft by lightly pulling it away from the drone.
  4. Protocol Galileo Stealth Housing Replacement: 步骤 4 中的图像 1,1
    • Remove the propeller from shaft by lightly pulling it away from the drone.
  5. Protocol Galileo Stealth Housing Replacement, Housing: 步骤 5 中的图像 1,2 Protocol Galileo Stealth Housing Replacement, Housing: 步骤 5 中的图像 2,2
    • Remove the 8mm long Phillips #0 screws (24 total) from the lower housing unit.
    • Take care to place the screws in a safe place to prevent losing them.
  6. Protocol Galileo Stealth Housing Replacement: 步骤 6 中的图像 1,1
    • Separate the upper and lower housing units by lightly pulling the two housing units apart.
结论
Matthew Selting
于02/15/18注册
432 声望
创作了4篇指南
团队
UW Stout, Team S8-G4, Ogden Spring 2018 UW Stout, Team S8-G4, Ogden Spring 2018 的会员
UWSTOUT-OGDEN-S18S8G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 149
