跳转到主内容
Protocol Dronium Two HD Camera Replacement
你所需要的
  1. Protocol Dronium Two HD Camera Replacement, Landing Gear: 步骤 1 中的图像 1,1
    • Turn device off by moving the selector switch to the left.
  2. Protocol Dronium Two HD Camera Replacement: 步骤 2 中的图像 1,2 Protocol Dronium Two HD Camera Replacement: 步骤 2 中的图像 2,2
    • Place one hand on the drone and carefully remove the landing gear with the other hand.
    • Be gentle as to not break off the studs on the landing gear.
  3. Protocol Dronium Two HD Camera Replacement, HD Camera: 步骤 3 中的图像 1,2 Protocol Dronium Two HD Camera Replacement, HD Camera: 步骤 3 中的图像 2,2
    • Use the fine edged plastic opening tool to pull up one side of the plug, and then the other, until it comes loose.
  4. Protocol Dronium Two HD Camera Replacement: 步骤 4 中的图像 1,2 Protocol Dronium Two HD Camera Replacement: 步骤 4 中的图像 2,2
    • Push the battery cover away from the drone and carefully open it up.
  5. Protocol Dronium Two HD Camera Replacement: 步骤 5 中的图像 1,2 Protocol Dronium Two HD Camera Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the two Phillips 5.35 mm screws holding the camera to the battery cover.
  6. Protocol Dronium Two HD Camera Replacement: 步骤 6 中的图像 1,1
    • Close the battery cover by pulling it towards you. Then, gently pull the camera towards you, freeing it from the battery cover.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 214
