跳转到主内容
Proscan Tablet Camera Replacement
你所需要的
  1. Proscan Tablet Camera Replacement, Camera: 步骤 1 中的图像 1,1
    • Tools necessary for task. Starting from the left to right Metal Spudyer Plastic opening tool Precision tweezer Point pen tool Driver with bit size J0
  2. Proscan Tablet Camera Replacement: 步骤 2 中的图像 1,1
    • The backing of the tablet is fastened by simply snapping it in. Using the metal opening tool, pry between the plastic backing and the edge, but do not remove it yet. Work your way around until you have them separated.
  3. Proscan Tablet Camera Replacement: 步骤 3 中的图像 1,1
    • Once you have finished going around the edges of the tablet, look inside.
  4. Proscan Tablet Camera Replacement: 步骤 4 中的图像 1,1
    • You can directly locate and remove the camera component in the corner. Simply unscrew the piece and gently remove the tape wire.
结论
另外一个人完成了本指南。
Cameron Denny
于10/23/15注册
321 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 384
