跳转到主内容
ProntoTec Axius Battery Replacement
你所需要的
  1. ProntoTec Axius Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table
  2. ProntoTec Axius Battery Replacement: 步骤 2 中的图像 1,1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
  3. ProntoTec Axius Battery Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
  4. ProntoTec Axius Battery Replacement: 步骤 4 中的图像 1,1
    • Using a spudger remove all the tapes that touches the battery.
    • Be careful not to cute any wires that are under the tapes
  5. ProntoTec Axius Battery Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, heat up the contact point of the red wire from the battery and the motherboard.
    • When the solder begins to melt, use pliers to gently pull the wire from the motherboard
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
  6. ProntoTec Axius Battery Replacement: 步骤 6 中的图像 1,1
    • Repeat Step 5 on the black wire connecting the battery to the motherboard as shown in the photo.
  7. ProntoTec Axius Battery Replacement: 步骤 7 中的图像 1,2 ProntoTec Axius Battery Replacement: 步骤 7 中的图像 2,2
    • Using a spudger, gently pry the battery from the back of the screen to remove it from the device.
结论
Antonio Irons
于10/20/16注册
441 声望
创作了4篇指南
团队
UMass Dartmouth, Team 5-3, Martin Fall 2016 UMass Dartmouth, Team 5-3, Martin Fall 2016 的会员
UMASSD-MARTIN-F16S5G3
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 411
