跳转到主内容
Promowide SP1790 Charging Port Replacement
你所需要的
  1. Promowide SP1790 Charging Port Replacement, Battery Wire: 步骤 1 中的图像 1,1
    • Locate the six screws on the back of the speaker.
  2. Promowide SP1790 Charging Port Replacement: 步骤 2 中的图像 1,1
    • Unscrew each of the six screws, then set them aside.
  3. Promowide SP1790 Charging Port Replacement: 步骤 3 中的图像 1,1
    • Gently remove the back cover of the speaker.
  4. Promowide SP1790 Charging Port Replacement: 步骤 4 中的图像 1,1
    • Place the speaker upside down.
    • Remove the battery cover located in the center of the speaker.
  5. Promowide SP1790 Charging Port Replacement: 步骤 5 中的图像 1,1
    • Locate and remove the four screws under each of the pads near the power socket.
  6. Promowide SP1790 Charging Port Replacement: 步骤 6 中的图像 1,1
    • Gently remove the bottom.
    • Do NOT pull out or damage wires.
  7. Promowide SP1790 Charging Port Replacement: 步骤 7 中的图像 1,1
    • Remove the single motherboard screw.
  8. Promowide SP1790 Charging Port Replacement: 步骤 8 中的图像 1,1
    • Remove both of the screws holding the power socket to the bottom chassis.
  9. Promowide SP1790 Charging Port Replacement: 步骤 9 中的图像 1,1
    • Desolder and remove the old wire.
    • Insert the new wire and solder it into place.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 949
