跳转到主内容
ProfiMixx 44 Disassembly
  1. ProfiMixx 44 Disassembly, Removing the scrapers: 步骤 1 中的图像 1,3 ProfiMixx 44 Disassembly, Removing the scrapers: 步骤 1 中的图像 2,3 ProfiMixx 44 Disassembly, Removing the scrapers: 步骤 1 中的图像 3,3
    • Removing the five (TR15) scrapers
  2. ProfiMixx 44 Disassembly, Removing the housing: 步骤 2 中的图像 1,2 ProfiMixx 44 Disassembly, Removing the housing: 步骤 2 中的图像 2,2
    • Removing the first part of the housing
    • Removing the rotary wheel, important pay attention to the black component so that the nose in does not break off (green mark).
    • Removing the second part of the housing
  3. ProfiMixx 44 Disassembly, Assembly of the housing I: 步骤 3 中的图像 1,3 ProfiMixx 44 Disassembly, Assembly of the housing I: 步骤 3 中的图像 2,3 ProfiMixx 44 Disassembly, Assembly of the housing I: 步骤 3 中的图像 3,3
    • Make sure that the green marked elements are in the right place in both housings, the red element is only available once.
    • Make sure that the two strands run as marked in blue.
    • The white element must be in the rear position. (marked in orange)
  4. ProfiMixx 44 Disassembly, Assembly of the housing II: 步骤 4 中的图像 1,3 ProfiMixx 44 Disassembly, Assembly of the housing II: 步骤 4 中的图像 2,3 ProfiMixx 44 Disassembly, Assembly of the housing II: 步骤 4 中的图像 3,3
    • Lift the motor-gearbox-unit a little bit upwards so that you can insert the black element with the nose into the hole of the white element. (marked in green)
    • Insert the nose of the black element into the hole of the rotary switch, making sure it is oriented as shown.
    • Gently move the rotary switch so that it fits into the slot in the housing. (marked in blue)
    • Then you can tighten the upper housing part with the five screws (TR15).
终点
Justus Klingler
于12/23/20注册
531 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 62
总计 1,511
