跳转到主内容
加入维修社区 - 创建账户
Professional Series PS77401 Shell Removal
你所需要的
  1. Professional Series PS77401 Shell Removal, Shell: 步骤 1 中的图像 1,1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Shell Removal: 步骤 2 中的图像 1,2 Professional Series PS77401 Shell Removal: 步骤 2 中的图像 2,2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Shell Removal: 步骤 3 中的图像 1,3 Professional Series PS77401 Shell Removal: 步骤 3 中的图像 2,3 Professional Series PS77401 Shell Removal: 步骤 3 中的图像 3,3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Shell Removal: 步骤 4 中的图像 1,2 Professional Series PS77401 Shell Removal: 步骤 4 中的图像 2,2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
结论
另外一个人完成了本指南。
Zachary
于01/23/14注册
243 声望
创作了2篇指南
团队
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G36
4 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 38
总计 928
