跳转到主内容
Professional Series PS77401 Power Cord Replacement
你所需要的
  1. Professional Series PS77401 Power Cord Replacement, Shell: 步骤 1 中的图像 1,1
    • Make sure that the toaster is unplugged before attempting any sort of disassembly!
  2. Professional Series PS77401 Power Cord Replacement: 步骤 2 中的图像 1,2 Professional Series PS77401 Power Cord Replacement: 步骤 2 中的图像 2,2
    • Grip the black plastic lever nub firmly and carefully remove it from the metal lever. Use one hand to hold the toaster in place while you pull the lever nub with the other.
    • If this is the first time detaching this piece, it will take some effort to remove. Be careful as pulling too hard can cause damage to the inner lever mechanism.
  3. Professional Series PS77401 Power Cord Replacement: 步骤 3 中的图像 1,3 Professional Series PS77401 Power Cord Replacement: 步骤 3 中的图像 2,3 Professional Series PS77401 Power Cord Replacement: 步骤 3 中的图像 3,3
    • Flipping the toaster upside down, use a T7 Torx Screwdriver to remove the four 10mm screws that keep the outer shell attached.
    • Flip the toaster back over and slide off the shell making sure to slip the toaster lever (now without the black plastic nub) through the lever opening in the shell.
    • The outer shell should now only be connected by its internal wiring.
  4. Professional Series PS77401 Power Cord Replacement: 步骤 4 中的图像 1,2 Professional Series PS77401 Power Cord Replacement: 步骤 4 中的图像 2,2
    • Locate and remove the two 8mm screws that attach the circuit board (located inside of the shell) from the shell itself using the Phillips #2 screwdriver.
    • The shell should now be completely separated from the rest of the toaster.
  5. Professional Series PS77401 Power Cord Replacement, Power Cord: 步骤 5 中的图像 1,2 Professional Series PS77401 Power Cord Replacement, Power Cord: 步骤 5 中的图像 2,2
    • Remove the small circuit board by pulling on the two side tabs while simultaneously releasing the middle clip.
    • Slide the small circuit board out of it's clips.
  6. Professional Series PS77401 Power Cord Replacement: 步骤 6 中的图像 1,2 Professional Series PS77401 Power Cord Replacement: 步骤 6 中的图像 2,2
    • Using a Philips #2 screwdriver, remove the front two 8mm screws attaching the chassis to the base.
    • Flip the toaster around and proceed to remove the two remaining 8mm screws.
  7. Professional Series PS77401 Power Cord Replacement: 步骤 7 中的图像 1,1
    • Upon removing the chassis, look in the toaster base to find the little white tab holding the power cord in place. Use a Philips screwdriver to remove the two 10mm screws.
  8. Professional Series PS77401 Power Cord Replacement: 步骤 8 中的图像 1,1
    • De-solder the two power cord wires that are connected to the small circuit board.
    • Solder on replacement power cord.
    • If you're unsure of how to solder here is a helpful guide: Soldering Guide
结论
另外一个人完成了本指南。
Zachary
于01/23/14注册
243 声望
创作了2篇指南
团队
Cal Poly, Team 10-36, Maness Winter 2014 Cal Poly, Team 10-36, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G36
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 578
