跳转到主内容
ProScan PLT7223G Front Facing Camera Replacement
你所需要的
  1. ProScan PLT7223G Front Facing Camera Replacement, Front Facing Camera: 步骤 1 中的图像 1,1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Front Facing Camera Replacement: 步骤 2 中的图像 1,1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Front Facing Camera Replacement: 步骤 3 中的图像 1,1
    • With a spudger, flip up the ZIF connector that connects the camera's ribbon cable to the motherboard. This will release the ribbon cable.
  4. ProScan PLT7223G Front Facing Camera Replacement: 步骤 4 中的图像 1,1
    • Remove the black tape holding down the ribbon cable.
  5. ProScan PLT7223G Front Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Remove camera.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 5
总计 327
