跳转到主内容
ProScan PLT7223G Battery Replacement
你所需要的
  1. ProScan PLT7223G Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove both 4 mm screws on the top of the tablet with a PH00 screw driver.
  2. ProScan PLT7223G Battery Replacement: 步骤 2 中的图像 1,1
    • Use the blue plastic opening tool to pry open the tablet.
    • You will hear popping sounds. That's okay.
    • Be careful when using the blue plastic opening tool on the side of the device near the speakers, as there is a wire here that connects the speakers to the motherboard.
  3. ProScan PLT7223G Battery Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Use a soldering tool and tweezers to remove the black and red wire from the motherboard.
    • Be sure to pay attention to where each wire goes so that you attach them in the correct order when reassembling the device.
    • Soldering tool will get hot, handle with care.
  4. ProScan PLT7223G Battery Replacement: 步骤 4 中的图像 1,1
    • Use a spudger to remove the black tape from the battery.
  5. ProScan PLT7223G Battery Replacement: 步骤 5 中的图像 1,1
    • Using the flat end of a spudger, carefully separate the battery from the base of the device.
    • There is an adhesive holding the charger in place.
结论
3等其他人完成本指南。
2指南评论
what is the number of the replacement battery??
florcomm - 回复
How will I know if my proscan tablet battery is no good once I remove it
Genica Harmon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 4,506
