跳转到主内容
ProScan PLT7050 Motherboard Replacement
你所需要的
  1. ProScan PLT7050 Motherboard Replacement, Open Device: 步骤 1 中的图像 1,1
    • Make sure device is unplugged and turned off while working on the device.
    • Remove 2 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  2. ProScan PLT7050 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tools to pry the back of the tablet open.
    • You may need to slide the tool along the sides of the device to get it to open. You might hear some popping noises, it is okay.
    • May be helpful if you start by the microSD slot.
  3. ProScan PLT7050 Motherboard Replacement, Motherboard: 步骤 3 中的图像 1,2 ProScan PLT7050 Motherboard Replacement, Motherboard: 步骤 3 中的图像 2,2
    • Remove the 3 black pieces of tape from the device.
    • Remove the 5 yellow pieces of tape from the device.
  4. ProScan PLT7050 Motherboard Replacement: 步骤 4 中的图像 1,2 ProScan PLT7050 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Use the soldering tool to remove the 3 wires from the mother board to the battery (black, red, gray).
    • Soldering tool will get hot.
  5. ProScan PLT7050 Motherboard Replacement: 步骤 5 中的图像 1,2 ProScan PLT7050 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Remove the speaker wires from the motherboard with the soldering tool.
  6. ProScan PLT7050 Motherboard Replacement: 步骤 6 中的图像 1,1
    • Remove 3 Phillips head, 4.3 mm screws from the bottom side of the tablet with a PH00 screwdriver.
  7. ProScan PLT7050 Motherboard Replacement: 步骤 7 中的图像 1,3 ProScan PLT7050 Motherboard Replacement: 步骤 7 中的图像 2,3 ProScan PLT7050 Motherboard Replacement: 步骤 7 中的图像 3,3
    • Use the plastic opening tool to pop open all 3 ZIF connector tabs connected to the motherboard.
    • Remove each ribbon from the ZIF connector port.
  8. ProScan PLT7050 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Lift the motherboard off the device taking care to pull the ports out of the casing.
结论
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 447
