跳转到主内容
加入维修社区 - 创建账户
Presto 0282202 Disassembly
你所需要的
精选文档
  1. Presto 0282202 Disassembly, Presto 0282202 Disassembly: 步骤 1 中的图像 1,3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: 步骤 1 中的图像 2,3 Presto 0282202 Disassembly, Presto 0282202 Disassembly: 步骤 1 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove the bottom two 25 mm screws off of the coffee percolator.
    • Lighty remove the bottom of the coffee percolator.
    • The wires will keep the two pieces connected.
  2. Presto 0282202 Disassembly: 步骤 2 中的图像 1,3 Presto 0282202 Disassembly: 步骤 2 中的图像 2,3 Presto 0282202 Disassembly: 步骤 2 中的图像 3,3
    • Using the Phillips #2 screwdriver, remove the center 10.8 mm screw holding in the metal strip.
    • Take off the metal strip.
  3. Presto 0282202 Disassembly: 步骤 3 中的图像 1,3 Presto 0282202 Disassembly: 步骤 3 中的图像 2,3 Presto 0282202 Disassembly: 步骤 3 中的图像 3,3
    • Lightly remove the right (bottom facing) thermal switch from its thermal paste.
    • Be careful as the thermal paste can be quite adhesive.
    • Using your small needle-nose pliers, take off the spade connectors connected to the thermal switch.
    • The easiest way to do this is to hold the thermal switch end with the pliers and tug the spade connector off.
  4. Presto 0282202 Disassembly: 步骤 4 中的图像 1,3 Presto 0282202 Disassembly: 步骤 4 中的图像 2,3 Presto 0282202 Disassembly: 步骤 4 中的图像 3,3
    • Lightly remove the left (side facing) thermal switch from its thermal paste.
  5. Presto 0282202 Disassembly: 步骤 5 中的图像 1,3 Presto 0282202 Disassembly: 步骤 5 中的图像 2,3 Presto 0282202 Disassembly: 步骤 5 中的图像 3,3
    • Remove the two spade connectors connected to the heating element.
    • The easiest way to do this is to hold the heating element end with the pliers and tug the spade connector off.
  6. Presto 0282202 Disassembly: 步骤 6 中的图像 1,3 Presto 0282202 Disassembly: 步骤 6 中的图像 2,3 Presto 0282202 Disassembly: 步骤 6 中的图像 3,3
    • Remove the two spade connectors connected to the power connector.
    • The easiest way to do this is to hold the power connector end with the pliers and tug the spade connector off.
    • The final wire removed contains the small heating wire (the thick braided wire) and the signal light.
结论
3等其他人完成本指南。
附加文件
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 33
总计 1,536
