跳转到主内容
加入维修社区 - 创建账户
Prep Black Wire
你所需要的
  1. Prep Black Wire, Wire: 步骤 1 中的图像 1,1
    • Locate QCPN#10669 which is a black hookup wire.
  2. Prep Black Wire: 步骤 2 中的图像 1,3 Prep Black Wire: 步骤 2 中的图像 2,3 Prep Black Wire: 步骤 2 中的图像 3,3
    • Measure out a 10cm length of wire.
    • Use a pair of flash cutters to carefully cut through the wire.
    • Caution: the wire must be no longer than 10.5cm and no shorter than 9.5cm in length.
  3. Prep Black Wire: 步骤 3 中的图像 1,1
    • Your wire should look like this now. #testedit
  4. Prep Black Wire: 步骤 4 中的图像 1,2 Prep Black Wire: 步骤 4 中的图像 2,2
    • Measure 20mm from either end of the wire.
    • With the flash cutters remove the instulation that is covering the wire.
    • Be careful not to cut to deep because you will damage the wire strands inside.
  5. Prep Black Wire: 步骤 5 中的图像 1,2 Prep Black Wire: 步骤 5 中的图像 2,2
    • Measure 10mm from the other side of the wire.
    • Remove the insulation from the wire with a pair of flash cutters.
  6. Prep Black Wire: 步骤 6 中的图像 1,1
    • Your finished wire should now look like this.
    • Remember to twist of the ends of the wire with your fingers so that the wire strands are not loose.
结论
You are finished.
6等其他人完成本指南。
Russell Frampton
于07/30/13注册
356 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 22
总计 582
