跳转到主内容
Pre-Lit Christmas Tree Incandescent Light Fuse Replacement
你所需要的
  1. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: 步骤 1 中的图像 1,2 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement, Fuse: 步骤 1 中的图像 2,2
    • Plug in the tree.
    • Use a Christmas light function tester to check the fuse on a light that is not bright.
    • The red light on the function tester will not light up if the fuse is dead.
  2. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 2 中的图像 1,1
    • Unplug the tree from the outlet.
  3. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 3 中的图像 1,3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 3 中的图像 2,3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 3 中的图像 3,3
    • Open the fuse cover, then use a small flathead screwdriver or spudger to carefully remove the fuse.
  4. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 4 中的图像 1,1
    • Using a continuity tester and the fuse, place both tips of the continuity tester on either side of the fuse.
    • The top light should light up red if the fuse is in working condition. If no light appears, repeat this step with a new fuse.
  5. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 5 中的图像 1,3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 5 中的图像 2,3 Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 5 中的图像 3,3
    • Carefully insert the working fuse back into the tree plug, and put the cover on.
  6. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 6 中的图像 1,1
    • Plug the tree back into the outlet.
  7. Pre-Lit Christmas Tree Incandescent Light Fuse Replacement: 步骤 7 中的图像 1,1
    • Using the Christmas light function tester, go back to the same spot you initially checked. If the red light appears, you have successfully replaced the fuse!
    • The red light will appear whether the bulb itself is working or not.
结论
Thank you for using this guide!
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 2,215
