跳转到主内容
PowerShot G7 X Mark II LCD Screen Replacement
你所需要的
  1. PowerShot G7 X Mark II LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Use a Philips #000 screwdriver to remove the three 2mm screws on the bottom of the LCD screen.
  2. PowerShot G7 X Mark II LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Tilt the LCD screen all the way up and use a Phillips #000 screwdriver to remove the three 4mm screws from the back of the LCD screen.
  3. PowerShot G7 X Mark II LCD Screen Replacement, Remove back panel from LCD screen: 步骤 3 中的图像 1,1
    • Use a spudger tool to release the ribbon cable from the ZIF connector.
    • The cable is thin and delicate. Detach with care.
    • Gently pry off the screen until the double-sided tape behind the back panel gives in.
  4. PowerShot G7 X Mark II LCD Screen Replacement: 步骤 4 中的图像 1,1
    • The screen is detached and can now be replaced.
结论
5等其他人完成本指南。
Brandon
于02/15/17注册
644 声望
创作了4篇指南
团队
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G3
3 名成员
创作了4篇指南
5指南评论
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - 回复
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - 回复
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
rachelkernali -
My G7X lost one of the 2 screws holding the screen: do you know where I can find them?
paolofarinella - 回复
on ebay or amazon. you can order it
nicole -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 29
过去 30 天: 156
总计 10,865
