跳转到主内容
PowerShot G7 X Mark II Front Cover Replacement
你所需要的
  1. PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: 步骤 1 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement, Top Cover Button Panel: 步骤 1 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove four 4mm screws from the NFC panel cover on the bottom of the camera.
  2. PowerShot G7 X Mark II Front Cover Replacement: 步骤 2 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove five screws from under the LCD screen:
    • Three 2.4 mm screws
    • Two 3 mm screws
  3. PowerShot G7 X Mark II Front Cover Replacement: 步骤 3 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove one 3mm screw on the left of the camera.
  4. PowerShot G7 X Mark II Front Cover Replacement: 步骤 4 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 4 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove one 3mm and one 4mm screw on the surface of the right face of the camera, and one under the USB/HDMI cover.
  5. PowerShot G7 X Mark II Front Cover Replacement: 步骤 5 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the back cover off of the camera by hand, minding the ribbon cable attached to the camera body. If the cover does not detach, use a spudger to pry it off.
    • Use the spudger tool to open the ZIF connector attaching the ribbon cable to the camera body.
  6. PowerShot G7 X Mark II Front Cover Replacement: 步骤 6 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the pop-up flash.
  7. PowerShot G7 X Mark II Front Cover Replacement: 步骤 7 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 7 中的图像 2,2
    • Use a Phillips #000 screwdriver to remove two 2mm screws attaching the button panel to the camera body.
    • Use a Phillips #000 screwdriver to remove a 3mm screw from beneath the mode dial.
  8. PowerShot G7 X Mark II Front Cover Replacement: 步骤 8 中的图像 1,3 PowerShot G7 X Mark II Front Cover Replacement: 步骤 8 中的图像 2,3 PowerShot G7 X Mark II Front Cover Replacement: 步骤 8 中的图像 3,3
    • Open the battery compartment and remove the battery by flipping the small latch holding it in.
    • Use a Phillips #000 screwdriver to remove one 6mm screw in the bottom of the battery compartment.
  9. PowerShot G7 X Mark II Front Cover Replacement: 步骤 9 中的图像 1,2 PowerShot G7 X Mark II Front Cover Replacement: 步骤 9 中的图像 2,2
    • Pry the top cover button assembly off of the camera body by detaching clips around the base of it.
  10. PowerShot G7 X Mark II Front Cover Replacement, Front Cover: 步骤 10 中的图像 1,1
    • Use a Phillips #000 screwdriver to remove two 3mm screws on the left and one 5mm screw on the right from the front panel.
  11. PowerShot G7 X Mark II Front Cover Replacement: 步骤 11 中的图像 1,1
    • Remove the USB/HDMI panel from the right side of the camera.
  12. PowerShot G7 X Mark II Front Cover Replacement: 步骤 12 中的图像 1,1
    • Separate the front cover and focus ring assembly from the front of the camera. Use a plastic spudger to detach the ZIF connector holding the ribbon cable connected to the focus assembly.
结论
2等其他人完成本指南。
Brandon
于02/15/17注册
602 声望
创作了4篇指南
团队
USF Tampa, Team 12-3, Eyestone Spring 2017 USF Tampa, Team 12-3, Eyestone Spring 2017 的会员
USFT-EYESTONE-S17S12G3
3 名成员
创作了4篇指南
一条评论
thank you so much for the guide!! extremely helpful, clear pictures, and easy to understand instructions.
victoria - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 44
总计 3,869
