此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本指南将向你展示如何更换相机的 LCD 屏幕。如果你的 LCD 屏幕出现破裂或无法工作,则需要进行此更换操作。
你所需要的
要重新组装设备,请按相反顺序执行这些说明。
5等其他人完成本指南。
5指南评论
Are there any problems with the replacement screen? It’s a touch screen, just making sure the functionality of the screen is still intact.
Andrew Baez - 回复 分享
These directions do not give enough information. The screed is glued into the frame. The replacement parts do not come with the circuit board.
alan saltus - 回复 分享
Did you successfully replace the screen? I took off the screws, and got to the detaching the wire stage but then discovered as you said “the glue”. Any further insight would be appreciated!
