跳转到主内容
PowerLead Puto PLD003 Tripod Clip Replacement
你所需要的
  1. PowerLead Puto PLD003 Tripod Clip Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Tripod Clip Replacement: 步骤 2 中的图像 1,1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Tripod Clip Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Tripod Clip Replacement: 步骤 4 中的图像 1,1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: 步骤 5 中的图像 1,2 PowerLead Puto PLD003 Tripod Clip Replacement, Tripod Clip: 步骤 5 中的图像 2,2
    • Apply pressure upwards to remove the tripod clip.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 4
总计 134
