跳转到主内容
加入维修社区 - 创建账户
PowerLead Puto PLD003 Side Panel Replacement
你所需要的
  1. PowerLead Puto PLD003 Side Panel Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Side Panel Replacement: 步骤 2 中的图像 1,1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Side Panel Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Side Panel Replacement: 步骤 4 中的图像 1,1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 25
总计 303
