跳转到主内容
PowerLead Puto PLD003 Back Buttons Replacement
你所需要的
  1. PowerLead Puto PLD003 Back Buttons Replacement, Side Panel: 步骤 1 中的图像 1,1
    • Slide the battery eject button open to release the battery door.
  2. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 2 中的图像 1,1
    • With the battery door open, carefully remove all four 5 mm Phillips #1 screws.
  3. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 3 中的图像 1,1
    • Rotate the camera so that the underside is facing up.
    • Remove the four 5 mm Phillips #1 screws.
  4. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 4 中的图像 1,1
    • Place the camera on a flat surface, with its underside facing you.
    • Gently pull up on the side panel to remove it from the camera.
  5. PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: 步骤 5 中的图像 1,2 PowerLead Puto PLD003 Back Buttons Replacement, Back Buttons: 步骤 5 中的图像 2,2
    • Remove the three 4 mm Phillips #1 screws holding the weight.
    • Remove the weight.
  6. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 6 中的图像 1,1
    • Remove the two 4 mm Phillips #1 screws holding the back panel in place.
  7. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 7 中的图像 1,1
    • Apply pressure to the back panel, away from the camera to remove.
  8. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 8 中的图像 1,2 PowerLead Puto PLD003 Back Buttons Replacement: 步骤 8 中的图像 2,2
    • Place the back panel so the buttons are facing down and the circuit board is facing up.
    • Remove the three 4 mm Phillips #1 screws holding the circuit board in place.
  9. PowerLead Puto PLD003 Back Buttons Replacement: 步骤 9 中的图像 1,1
    • Set aside the circuit board.
    • These nubs are what is currently holding the buttons in place.
    • Carefully apply pressure and remove the set of buttons from the nubs.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 258
