跳转到主内容
修复你的物品
维修的权力
商店
简介
The bottom case slides off easily after removing a few T8 Torx screws.
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
  1. 打开所有标签
    Mac的RAM升级套装
    购买套装
    所有选项卡都有足够的 RAM
    购买套装
  2. Using your thumbs, slide the lower case away from you.
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. Your laptop should look approximately like this.
    • Your laptop should look approximately like this.
结论
附加文件
iRobot
于2009年09月24日注册
1 信誉积分
创作了648篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 2
总计 3,816
