跳转到主内容
PowerBook G4 Titanium Onyx Hard Drive Replacement
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
    • Turn the G4 over.
    • Remove the eight T8 Torx screws from the lower case.
  1. PowerBook G4 Titanium Onyx Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using your thumbs, slide the lower case away from you.
    • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  2. PowerBook G4 Titanium Onyx Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Your laptop should look approximately like this.
  3. PowerBook G4 Titanium Onyx Hard Drive Replacement, Airport Card: 步骤 4 中的图像 1,1
    • Skip this step if your computer does not have an Airport card.
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
  4. PowerBook G4 Titanium Onyx Hard Drive Replacement, Hard Drive: 步骤 5 中的图像 1,1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
  5. PowerBook G4 Titanium Onyx Hard Drive Replacement: 步骤 6 中的图像 1,1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  6. PowerBook G4 Titanium Onyx Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  7. PowerBook G4 Titanium Onyx Hard Drive Replacement: 步骤 8 中的图像 1,1
结论
4等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 5,020
