简介
56k internal modem, standard on all models.
你所需要的
Remove the battery.
Turn the keyboard locking screw so that it is parallel to the space bar.
Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Please do steps 7 and 8 before you do 5 and 6, because opening the lid without the bottom plate screwed in place easily breaks the plastic around the powerbook as it is pretty fragile after 20+ years. Mine broke even further as it already hat started an to get the bottom top screws back on I had to flip open the display, beg for it not to fall off and let it hang over my table, so the stress from the hinges would be released. It all fit back together, but is broken more than before, changing the PRAM battery (it’s under the dvd drive) went well and the laptop finally turned on again :)
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Before continuing, place a soft cloth on your work surface to rest the computer on. Turn the G4 over, making sure the DVD drive doesn't fall out.
Carefully peel the adhesive strip away from the DVD drive. The plastic dust shield covering the DVD drive is easily damaged. Try to start at the four corners and work toward the center.
Turn the G4 over.
Using a 5 mm nut driver or needle-nose pliers, remove the hex nut from the modem.
