简介
You can install hard drives up to 12.5mm thick.
你所需要的
Using your thumbs, slide the lower case away from you.
Lift the lower case off.
Please do steps 7 and 8 before you do 5 and 6, because opening the lid without the bottom plate screwed in place easily breaks the plastic around the powerbook as it is pretty fragile after 20+ years. Mine broke even further as it already hat started an to get the bottom top screws back on I had to flip open the display, beg for it not to fall off and let it hang over my table, so the stress from the hinges would be released. It all fit back together, but is broken more than before, changing the PRAM battery (it’s under the dvd drive) went well and the laptop finally turned on again :)
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
14等其他人完成本指南。
附加文件
2条评论
I am old 85 and recovering from a stroke my apple titanium lap top was working when I had my stroke but was unplugged from the mains for months daughter moved it from my study to make way for hospital bed. Now trying to look at photos etc it is completely dead! Just a black screen no sounds at all. Any one advice a simple thing I could try. Old but I love it have a iPad prw no Few years old but cannot remember exactly since my memory damaged. Any advice to help recover my old friend welcome. It looks like new as cared for it .thanks in advance Jeanette
Jeanette, you have to disconnect the small batteries from the PMU unit. Then you have to plug in your power supply and reconnect the small batteries to the PMU unit.
Good luck
Harald Mohr
