跳转到主内容
PowerBook G4 Titanium DVI Latch Replacement
你所需要的
  1. PowerBook G4 Titanium DVI Latch Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Titanium DVI Latch Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Latch Replacement, Lower Case: 步骤 2 中的图像 1,2 PowerBook G4 Titanium DVI Latch Replacement, Lower Case: 步骤 2 中的图像 2,2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Latch Replacement, Hard Drive: 步骤 3 中的图像 1,1
    • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
  4. PowerBook G4 Titanium DVI Latch Replacement: 步骤 4 中的图像 1,1
    • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
  5. PowerBook G4 Titanium DVI Latch Replacement: 步骤 5 中的图像 1,1
    • Remove the hard drive by lifting the left edge up and out of the computer.
    • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
  6. PowerBook G4 Titanium DVI Latch Replacement: 步骤 6 中的图像 1,1
    • Your laptop should look approximately like this.
  7. PowerBook G4 Titanium DVI Latch Replacement, Latch: 步骤 7 中的图像 1,1
    • Use your thumbnails to push in and then lift the two fingers of the latch clip over the restraining bar.
  8. PowerBook G4 Titanium DVI Latch Replacement: 步骤 8 中的图像 1,1
    • Now use your index fingers' nails to pull at the "elbows" of the clip, rotating it upward approximately 90 degrees, or until the latch pops out
  9. PowerBook G4 Titanium DVI Latch Replacement: 步骤 9 中的图像 1,1
    • Insert the new latch by rotating the clip up and pushing the latch into place. Then rotate the clip back down, pushing in at the area where the clip bends around the latch. Make sure to insert the clip fingers back into their slots.
结论
5等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 4
过去 30 天: 22
总计 8,023
