简介
The inverter powers the LCD backlight and is not a difficult part to replace.
你所需要的
Locate the battery release tab on the underside of the G4.
Slide the battery release tab to the left and lift the battery out of the computer.
Remove the seven T8 Torx screws from the lower case.
Using your thumbs, slide the lower case toward the front of the computer.
The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
Lift the lower case off.
Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger.
To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
I suspect you are meant to remove the two T8 Torx screws holding down the drive retaining bar on the other side of the hard drive. Once the bar is removed, the drive will pivot out without having to touch the screws on the battery housing wall side.
John Hagan - 回复
I agree with John Hagen. The correct way to remove the hard drive is to remove the two T8 Torx screws and drive retaining bar, then lifting the hard drive up on the side by the optical drive . This will prevent a lot of frustration, and potential damage to the plastic shield underneath the hard drive and the rubber bumpers over the hard drive screws.
John Nakai - 回复
Yes, this is totally better than removing the hard drive screw on the left side of the hard drive as instructed.
Anthony -
Remove the hard drive by lifting the left edge up and out of the computer.
The hard drive can be removed with its bumpers intact, by just taking off the black plastic clamp to its right. Reinserting the drive is also vastly easier when done this way.
Disconnect the pink and white inverter cable from the inverter board.
The pink and white inverter cable connection to the inverter board is very tight. Grasp the notch on the right side of the white connector with needle nose pliers and gently wiggle and pull it out of the socket.
Sugar Fish - 回复
Remove the two T6 Torx screws from the modem.
Lift the modem off the optical drive, carefully guiding the orange ribbon cable through the space in the drive mount.
Remove the two T6 Torx screws from the inverter board.
Lift the inverter board off the optical drive.
12等其他人完成本指南。
