跳转到主内容
PowerBook G4 Titanium DVI Airport Card Replacement
你所需要的
  1. PowerBook G4 Titanium DVI Airport Card Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Titanium DVI Airport Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Locate the battery release tab on the underside of the G4.
    • Slide the battery release tab to the left and lift the battery out of the computer.
  2. PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: 步骤 2 中的图像 1,2 PowerBook G4 Titanium DVI Airport Card Replacement, Lower Case: 步骤 2 中的图像 2,2
    • Remove the seven T8 Torx screws from the lower case.
    • Using your thumbs, slide the lower case toward the front of the computer.
    • The lower case may stick in the front on a tab just above the center of the optical drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
    • Lift the lower case off.
  3. PowerBook G4 Titanium DVI Airport Card Replacement, Airport Card: 步骤 3 中的图像 1,1
    • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
    • Disconnect the antenna cable from the left side of the Airport card.
结论
19等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 22,393
