当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
Use your fingertips to pull the two RAM arms away from the sides of the RAM chip. The chip should pop up slightly.
Pull the RAM chip away from its socket and remove it from the logic board.
Repeat this process for the other RAM chip, if present.
取消:我没有完成这个指南。
24等其他人完成本指南。
Aluminum-17"-Screw-Guide.pdf
PDF - 548.05 kb
与7其他贡献者
695,077 声望
创作了1,203篇指南
徽章: 54
+ 51更多徽章
What is the maximum ram that I can bump up this system to?
Legendary Ocelot - 2018年4月16日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 8,347
