跳转到主内容
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement
你所需要的
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Memory Door: 步骤 2 中的图像 1,1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 3 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 3 中的图像 2,2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Upper Case: 步骤 4 中的图像 1,1
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 5 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 5 中的图像 2,2
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 6 中的图像 1,1
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 8 中的图像 1,1
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 9 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 9 中的图像 2,2
    • Depress the display latch release button and open your display.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 10 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 10 中的图像 2,2
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
  11. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Optical Drive: 步骤 11 中的图像 1,1
    • Use the flat end of a spudger to pry the optical drive cable connector up off the logic board.
  12. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 12 中的图像 1,1
    • Remove the following four screws securing the optical drive to the lower case:
    • Three 6.8 mm T8 Torx.
  13. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 13 中的图像 1,1
    • Lift the optical drive out of the lower case, being careful not to disturb the PRAM battery & USB board ribbon cable.
  14. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement, Optical Drive: 步骤 14 中的图像 1,1
    • Use the flat end of a spudger to separate the optical drive connector from the optical drive.
    • If necessary, pull the optical drive cable away from the optical drive.
  15. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 15 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 15 中的图像 2,2
    • Remove the two Phillips screws holding the optical drive bracket to the side of the optical drive.
    • Pull the optical drive bracket away from the thin side of the optical drive.
  16. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 16 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Optical Drive Replacement: 步骤 16 中的图像 2,2
    • Remove the two Phillips screws securing the flat optical drive bracket to the side of the optical drive.
    • Remove the optical drive bracket.
    • If you have a disk or anything else stuck inside your optical drive, we have a guide to fix it.
结论
4等其他人完成本指南。
附加文件
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 10,025
