本指南有最近更改,您可查看未经巡查的最新版本。
简介
Remove your memory door to access the RAM chips.
你所需要的
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
即将完成!
结论
另外一个人完成了本指南。
