简介
Replacing your lower case requires removing nearly every component from your PowerBook.
你所需要的
Use your thumbs to push the two battery retaining tabs away from the battery.
The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
Remove the following ten screws:
Two 14.7 mm shouldered Phillips.
Three 12.3 mm Phillips.
One 3.8 mm T8 Torx.
One 6.8 mm T8 Torx.
Three 1.3 mm Phillips.
Close your PowerBook, minding any cables that may interfere, and flip it over.
Disconnect the power cable connector by pulling it straight away from its socket on the logic board.
Use the flat end of a spudger to pry the modem cable connector up off the modem.
Remove the following four screws:
Three 11.1 mm T8 Torx.
One 3.9 mm T8 Torx.
Lift the hard drive out of the lower case.
