跳转到主内容
修复你的物品
维修的权力
商店
简介
Replace a worn out battery for longer intervals between recharging.
工具
没有特定工具。
配件
  1. Use your thumbs to push the two battery retaining tabs away from the battery. The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
结论
2等其他人完成本指南。
附加文件
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
Legendary Ocelot - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 4
总计 2,856
