跳转到主内容
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
你所需要的
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: 步骤 1 中的图像 1,2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
结论
2等其他人完成本指南。
附加文件
一条评论
Where can I find new condition batteries for this. I can’t seem to find any compatable ones.
Legendary Ocelot - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 3,116
