当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Loosen the trackpad connector by pulling the locking bar toward the battery housing, using the tips of your fingers.
Slide the trackpad cable out of the loosened connector.
Note: When reassembling the case, the trackpad cable can get stuck below the slot to the motherboard. It's possible to nudge it out slowly by gently prodding it on either side with a small screwdriver. You don't need to use much force to do this. Eventually it will just pop back out and you can reconnect as per the instructions above. Also, note that the locking bar comes loose so if you see a little piece of plastic lying around when reassembling, that's what it is. :)
这个步骤还没有翻译 帮忙翻译一下
Remove the following 10 screws from the bottom case:
Three 1.7 mm Phillips from the front edge of the battery compartment.
One 3.9 mm T8 Torx to the right of the memory card.
One 6.9 mm T8 Torx at the left edge of the memory compartment.
Three 12.4 mm fully threaded Phillips from the center of the row of screws along the back edge of the case.
Two 15.1 mm 2.5 mm threaded Phillips, one from either end of the row of screws along the back edge of the case.
这个步骤还没有翻译 帮忙翻译一下
Remove the following 12 T8 Torx screws from the logic board:
Four 3.9 mm, three along the front edge of the logic board, and one just above the right fan connector.
Three 6.9 mm large-headed screws in the upper, left corner of the logic board.
Five 6.9 mm scattered on the right half of the logic board.
这个步骤还没有翻译 帮忙翻译一下
Grasp the logic board at the left edge with one hand and at the thinnest section with the other hand. Lift the left edge of the board up to approximately a 30 degree angle (if you don't have your protractor handy, just lift until the DVI port clears the right hinge).
Once the logic board clears the ports, slide it out to the left.
10等其他人完成本指南。
附加文件
3条评论
All steps: photos seem to be missing (sept 21, 2015) from Steps 5, 8, 9, and 19. Any chance of getting them restored? Also, numerous pieces of yellow translucent scotch-like tape appear to hold cables out of the way, but are now dried out & non-sticky; can I use regular scotch-like tape for re-assembly, or is this some special stuff that needs to be replaced with like? If the latter, what is it called & where can it be acquired?
You can get a kapton tape (the same stuff it was originally used)
oldnwstf -
