跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
你所需要的
  1. , 电池: 步骤 1 中的图像 1,1
    • 使用一个硬币插入电池锁扣的凹槽内,然后顺时针旋转90度。
    • 此时电池会被顶起一部分,可以很方便地把它从电脑上取下。
  2. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 2 中的图像 1,1
    • Remove the following 10 screws:
    • Two 3 mm Phillips in the battery compartment, on either side of the battery contacts.
    • Four 3 mm Phillips around the memory compartment.
    • Four 16 mm Phillips along the hinge.
  3. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 3 中的图像 1,1
    • Remove the memory compartment cover.
    • Remove the two 12 mm Phillips screws on the Aluminum bracket at the top of the memory compartment.
  4. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 4 中的图像 1,1
    • Rotate the computer 90 degrees clockwise so the power receptacle faces you.
    • Remove the three 3 mm Phillips screws along the edge of the lower case.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer.
  5. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 5 中的图像 1,1
    • Turn the computer 90 degrees clockwise so the hinge faces you.
    • Remove the lower 5 mm Phillips screw on each side of the hinge (two total).
  6. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 6 中的图像 1,1
    • Rotate the computer 90 degrees clockwise so the ports face you.
    • When replacing these screws, you must install them in the correct order. Begin by installing the screw closest to the display hinge, then work your way toward the front of the computer. Also, be careful not to put the screws in the two holes on either side of the video out port.
  7. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 7 中的图像 1,1
    • Turn the computer over and open the display.
    • Remove the two 4.2 mm long, 1.5 mm hex screws at the top corners of the upper case (two total).
    • A T6 Torx driver will work, but repeated use will strip the screws.
  8. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 8 中的图像 1,1
    • Grasp the back corners of the upper case and pull up.
    • Do not pull the upper case off yet; you still need to disconnect the keyboard and trackpad cable.
    • Lift the back of the case up and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case.
  9. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 9 中的图像 1,1
    • Rotate the upper case up and toward the screen, so that the upper case rests against it.
  10. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 10 中的图像 1,1
    • Remove the amber tape securing the trackpad ribbon to the logic board.
    • Disconnect the trackpad ribbon from the logic board by pulling up on the connector.
    • Remove the upper case from the computer.
  11. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 11 中的图像 1,1
    • Remove the 12 mm Phillips screw holding the right speaker assembly to the lower case.
  12. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 12 中的图像 1,1
    • Use a spudger to gently pry the speaker out of its housing.
    • The right ambient light sensor cover is connected to the speaker and should not be removed.
  13. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 13 中的图像 1,2 : 步骤 13 中的图像 2,2
    • Disconnect the hard drive and optical drive connectors from the logic board.
    • Disconnect the right speaker cable connector.
    • De-route the right speaker cable and remove the speaker from the computer.
    • The right speaker cable may be trapped under the hard drive cable connector. If this is the case, the hard drive will have to be removed in order to de-route the cable and remove the right speaker.
终点
附加文件
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 4,830
