跳转到主内容
PowerBook G4 Aluminum 12" 867 MHz RAM Replacement
你所需要的
  1. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Use a coin to turn the battery locking screw 90 degrees to the right.
    • Lift the battery out of the computer.
  2. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • Remove the four Phillips screws from the memory door.
    • Slide the memory door away from the memory compartment.
  3. PowerBook G4 Aluminum 12" 867 MHz RAM Replacement: 步骤 3 中的图像 1,1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connectors.
结论
6等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 10,623
