本指南有最近更改,您可查看未经巡查的最新版本。
简介
Save money by replacing your broken LCD element.
你所需要的
Use a coin to turn the battery locking screw 90 degrees to the right.
Lift the battery out of the computer.
Insert a plastic opening tool between the left edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Rotate the tool away from the LCD to pop the rear bezel off the tabs on the front display bezel.
Work along the left edge of the display until the rear bezel is evenly separated from the front bezel.
Insert a plastic opening tool between the right edge of the front display bezel and the plastic strip attached to the rear bezel, with the edge of the tool angled toward the LCD.
Work along the right edge of the display until the rear bezel is evenly separated from the front bezel.
Insert the pointed end of the a spudger between the protective tape and the inverter board.
Carefully pull up with the spudger to lift the inverter board out enough to access the connector cables.
Once you can easily grab the board, pull it up enough to gain access to the inverter board's output connector.
4等其他人完成本指南。
