本指南有最近更改,您可查看未经巡查的最新版本。
简介
Replacing this keyboard is easy and takes only a few minutes.
你所需要的
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
8等其他人完成本指南。
