跳转到主内容
PowerBook G3 Wallstreet Heat Shield Replacement
你所需要的
  1. PowerBook G3 Wallstreet Heat Shield Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Remove both expansion bay modules using the levers on the front of the computer.
    • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
    • Pull the tabs toward yourself and the keyboard will pop up.
  2. PowerBook G3 Wallstreet Heat Shield Replacement: 步骤 2 中的图像 1,1
    • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
    • Rest the keyboard on the trackpad.
    • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
    • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
    • 2) After disengaging the locking bar, slide the cable out of the connector.
  3. PowerBook G3 Wallstreet Heat Shield Replacement: 步骤 4 中的图像 1,1
    • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
  4. PowerBook G3 Wallstreet Heat Shield Replacement: 步骤 5 中的图像 1,1
    • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
    • Once the strain relief cables are free, lift the keyboard off.
  5. PowerBook G3 Wallstreet Heat Shield Replacement: 步骤 6 中的图像 1,1
    • Your laptop should look approximately like this.
  6. PowerBook G3 Wallstreet Heat Shield Replacement, Heat Shield: 步骤 7 中的图像 1,1
    • Remove the two Phillips screws from the heat shield.
    • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
  7. PowerBook G3 Wallstreet Heat Shield Replacement: 步骤 8 中的图像 1,1
    • Grasp the metal handle on the heat shield and pull up and toward yourself.
结论
另外一个人完成了本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 4,238
