当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Remove both expansion bay modules using the levers on the front of the computer.
Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
Pull the tabs toward yourself and the keyboard will pop up.
40等其他人完成本指南。
附加文件
2条评论
You absolutely do not need to remove the keyboard ribbon cables in order to replace the hard drive. You just need to be careful and the HDD caddy will come out just fine. As someone who has had some bad experiences with ribbon cables, I prefer not to remove them unless absolutely necessary.
