当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Use the lever at the front of your laptop to remove the optical drive bay from the computer.
Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
These screws are longer than those on the other side.
Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
