跳转到主内容
PowerBook G3 Pismo Optical Drive Replacement
你所需要的
  1. PowerBook G3 Pismo Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Use the lever at the front of your laptop to remove the optical drive bay from the computer.
    • Remove the 2 Phillips #00 screws from the left side of the optical drive housing.
    • These screws are longer than those on the other side.
  2. PowerBook G3 Pismo Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the 2 Phillips #00 screws from the other side.
  3. PowerBook G3 Pismo Optical Drive Replacement: 步骤 3 中的图像 1,1
    • Grasp the black drive housing in one hand and the drive itself in the other, then slide the two apart.
    • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
结论
6等其他人完成本指南。
附加文件
iRobot
于09/24/09注册
1 声望
创作了636篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 8,701
