当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the computer so that the ports are facing you.
If the keyboard is locked, open the port cover and turn the keyboard locking screw until the keyboard is unlocked.
Lift the keyboard out by pulling it up and away from you. Rest the keyboard, face down, on top of the trackpad.
In order to replace the keyboard, you must first remove the modem.
Disconnect the keyboard cable from the logic board by pulling directly up on the clear plastic loop.
This step is out of sequence with the keyboard because in order to remove the keyboard you must first remove the modem.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
